Theres no fuses for TAPS 3. Driven by PDM (Power Distribution Module). PDM diagnostic screen while show faults(opens, shorts, etc) What is your TAPS3 not doing??
When I switch from left to right nothing happens. I’ve had the boat for 2 years so I know pretty well what it should be doing.
I also had it prepped for the summer by our local boat guy but I think he didn’t tighten the battery terminals properly and we had some ground faults. They seem to have gone away after tightening the terminals.
Not sure the history you have had but it took 3 sets of Rams maybe 4 on my 2016 R20 to get mine to consistently operate properly. That’s even after getting it working fine over a summer put it up for winter then start of next season it wouldn’t work. They finally swapped everything out to the 2018 setup so far so good.
