Some more info is needed. What is you current prop?? What's the elevation where you primarily boat?? You looking for best surf prop that pushes big weight?? You looking for something that still has some top end and surfs??
I dont have a ton of anecdotal evidence as I haven't spent much time on the boats with 2:1s, which I'm guessing you have. Look at the hub to confirm. If you have 1 1/4 stamped on it you are a 2:1.
Wakemakers list an Acme 3163 as the middle ground prop. Acme 2907 for the heavily weighted/high altitude. You probably dont want the 2907 if you are wanting to keep some top end.
Wakemakers also lists the 2693 but only slightly bigger and basically same pitch so I dont think you will notice much change.
Hopefully others with more anecdotal evidence can chime in but I'd go with the 3163 if you arent going to run lots of lead/additional ballast and arent also filling the boat full of people.
