I have a 2015 RZ2. While cruising has anyone every had it slip out of drive into neutral? My reaction was to pull the throttle back quickly to idle, then the engine revs without going back into gear. I shut the engine and battery off to see if I could get it out of this state. Then the engine wouldn’t start, (as if the throttle was not in neutral). After a while the engine started and I was able to get back to the ramp keeping the speed and RPM down in case it slipped out of drive again. Has anyone experienced a problem like this before? Advice welcome.
