Originally posted by Zackdogg
View Post
Couple of quick questions
There is a USB port hanging behind the touchscreen.
Only thing with the above instructions is the part about holding the top left button. That's for the 7" screens. (TT2)
The 10" (Clear) just has the "Update" button in the settings screen and after you pick the file it will go to the bootloader then install the OS update.
Unless my memory is shot and some 16 RZXs got 7" screens.
Originally posted by freeheel4life View PostAlso, what is # in the little box next to the folder?
I don’t have anything out here that will read a usb, so I can’t verify that the file is there, but the above file was the one I downloaded. It was a weird file type, pvi, or something, and almost 80MB.. maybe something was wrong there. I guess I should have brought a laptop out to try and figure it out. I was in a big rush to get to the lake, after work. I could have easily done something wrong.
If anyone would get out of their beds, I’d be on the water, which is where I should be!!!
was the thumb drove formatted correctly prior to loading the file? This to have been an issue for others.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
That's rough buddy. Just start blasting the Revs!!
So do you have a Polk head unit in the glovebox??
That file wont load because it's for the 10" Clear. The BL at the front of the file name is how I know. Koolaid probably assumed as did I you had a 10". I'm omw in to the shop now and have the file you need, but need to know if you have the Polk in the glovebox because if I screw it up you will have no stereo
PM me you email address and it will be waiting for you when you get back. Enjoy your lake time!!
