Hey dudes! Couple of minor projects going before the lake this weekend, and was hoping someone knew the answers to. Replacing surf plate actuators, and throwing a couple of transom lights in, while I’m there.
What sealant should I use for the transom lights and the wire to the actuators? Planning on 5200, but just making sure.
I think I read at one point that the open black and blue wire that’s zip tied up on each side, actually to the actuator wires, are for the transom lights. And Red on the light to Blue on the boat, and black to black, for wiring?? If anyone can verify, I would appreciate it.
Do I need to do something on the touchscreen to activate the transom lights? I thought I read that at one point, also. I might be as simple as going in to dealer mode and turning it on, I haven’t played with it yet.
Koolaid, if you read this, I’m still hoping to get those bow plugs. Does anyone know what size those holes should be drilled to? And, if I drill them with out the plugs, is that water going to end up somewhere weird? Or will it find it’s way to the bilge, anyways? I’m really sick of bailing the bow out with whatever plastic cup I can find, after I lost my super soaker.
As always, thanks for any help!!!!
Z
Z
