Looks like the starter has gone bad on my 2010 RZ2 with a PCM 343. Was on the lake yesterday and only way to crank boat was to hit starter with hammer while someone turned ignition switch. This worked every time we needed to crank thankfully. I wanted to know if anyone could link the exact replacement starter because I'm having trouble finding the part number. Also, if anyone has experience replacing the starter on this particular model, let me know if it can be a DIY job for a novice.
2010 Tige RZ2 Replacement Starter for PCM 343
I had my starter rebuilt last year. May take longer timing wise than you want instead of direct replacement but is also an option. Also very fairly straight forward to replace. One bolt on the bottom side is a bit of a PITA.
This is from a 2009 user manual but shouldn't be any differentAttached Files
