Quick question regarding the trans oil light on my dash - boat is a '99 21v with the 350 MAG MPI with around 850 hours. Over the weekend I noticed that the tans light seems to be flickering a bit when on plane. Usually the light turns off at anything over 700ish RPM. Transmission fluid level was changed last season and is clean and full. I believe the light I am seeing could be related to the v-drive oil? I have not changed that for a few seasons so I was going to start with inspecting that.
What would cause the v-drive oil level to get low if that is indeed the case? Could it be leaking from somewhere that I should be inspecting? Any insight would be much appreciated. V-drive is the black 1.00-1 Walter Gear Drive s/n 80749 and p/n RV-26D.
Thanks!
Thanks!
