Hey everyone, pretty new to the Tige world and love our 22Ve. We had the steering cable replaced last summer and it made a huge difference, but it is already getting harder to turn the wheel. Shouldn't they last longer than a year?
1 year old steering cable
Did they use the Extreme series cable and run it over the gas tank? There is also a mod that grounds the rudder/cable to deal with galvanic corrosion. Allows the cable to last longer.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
The cable won’t last long if it gets submerged in the bilge regularly. These boats can hold quite a bit of water in the bilge under the tank without it being apparent just by looking into the engine bay. Best to make sure you dry the bilge between uses.
I pull my plug and then pull the boat onto a steep part of the ramp for a minute or so after pulling the boat out of the water.Last edited by Jetdriver; 05-28-2019, 07:34 AM.
