2008 Tige Z! Proper Engine Running Temp
    Hey Guys!
    I was on the lake today, and I noticed my engine was only getting to about 140 degrees. I thought it usually runs warmer than that.... I just replaced a thermostat in my Aunt's boat that wasn't getting above 110 degrees. The thermostat was stuck open.... Her boat had a Mercruiser 5.0 (305) and called for a 160 Thermostat. I can't find a definitive answer online for my engine, and I was hoping someone on here could help... I know that an engine that is not running at the temperature that it is supposed to is bad.....Hot or Cold....
    2008 Tige Z1
    Marine Power 340 Horse
    Thanks!!!
    Average should be around 160-165 once warm.
    Editing as I'm forgetting you don't have a PCM 343 in the 08. Above is normal for PCM. Can't confirm on the older.
      Thanks anyway! If I ever own the 343, I'll know!!!
      Sent from my SAMSUNG-SM-J727A using Tapatalk
