Originally posted by wired1236
View Post
18 R23 surf setup changes...what happened?
Originally posted by freeheel4life View Post^^Yup. And just to throw one more to keep an eye out for(and because my poop stinks too), it's possible as the drill bit comes thru the transom to poke the drain hose on the port side. Havent had a comeback for the brackets the wrong way but have had 2 for complaints of drain issues. Got in and found this....Both hoses that got poked were (of course) behind the batteries.
I just spent all day on and off the lake, in and out of the dealership all to find out that the dealer had installed the top brackets for the surf plates backwards. They also do not use proper or enough sealant and I was leaking probably 4 gallons an hour into the bilge.
I believe you have the same color scheme as mine right ...blue n silver? They installed the update in early December and I believe you saw my boat there.
They fixed it in about an hour or so.
The top brackets were preventing the plates from being stowed up high enough which caused the plates to always be in the water. It actually made the steering to have strange behaviors too
Originally posted by Bamer View PostFreeheel4life,
What sealant did tige call out to be used with the updated brackets?
I use the boat life white. Skins over in a few hours and has some good body to it and does not run off of a vertical surface.
I rarely have the need for a permanent like 5200.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostI use the boat life white. Skins over in a few hours and has some good body to it and does not run off of a vertical surface.
Originally posted by cnote View Postyes, Bamer, eagle marine. it was done over the winter. I keep the boat stored at PK so will be out next week to check and fix, if needed. hope the bracket reversed is the fix and it's simple
I think my plates are still not stowed up high enough because as I pitch the boat up the wave goes away completely. I did not measure the angle, but I’m not talking about a lot of pitch. Any center plate position above 5 would wash out the wake. Is this normal?
Originally posted by Bamer View PostCnote , Did you get ur R23 to surf with the new brackets?
anyone else out there having luck?
anyone of our other tige experts offer anything here?
Originally posted by cnote View Postbrackets were done correctly, according to freeheel's advice. so, yes, still having same issue. i can't pitch higher than about 6 degrees (used to be 11) or wave washes out. it also seems to be a lot more finicky, any turn or side wake also washes it out. the overall effect is wave is not as tall, about same length. tried speeding up, adjusting taps, but pitch and roll were about 6/2-3 degrees respectively to have any sort of clean wave. I'm pretty disappointed right now. throwing 900# of lead plus full water ballast and about 800# of people should give me a better wave, more push, taller, etc. and last year we had it. don't get me wrong, it's not a bad wave, but right now the Malibu 23lsv i surf with dfw surf l is a better wave, hands down. last year it was 50/50. going to keep playing with it though. my next step is throw in some extra tsunami sacks to see what that gets me. i hope i can get this worked out because the wave can be better.
2018 R21 that has also had the new TAPS ram reposition completed.
Previously, our normal set up was 4 and 4 on the surf and center tab and 11.6 for speed. Same set up the same as last year with ballast and lead. Wave was killer. Only difference from last year was that the port front ballast would not fill (fill pump has failed for some reason after working fine prior to storage). I was able to compensate for the lack of weight in the bow with moving some people and lead around.
Was out for the first time since the modification a couple days ago and I also found my previous settings were not working AT ALL.
Using my previous settings the wave was all washed out. Tried a bunch of different taps setting and speeds and I ended up with a 2 on surf and 1 on the center tab with 11.6 to get a descent wave, but was still thought it was not as good as last year. I thought it was mostly due to the port front ballast not being full, but maybe there is something similar going on here after the ram adjustment?
I haven't checked the fore/aft position of the bracket but I will check today after work to rule out that issue.
Boat is going to the dealer this week for the ballast pump fix and I'll see what they have to say as well...
