You guys may remember my attempt at building a TAPS3 system for my old 21v a couple years ago. See the thread here if you want a quick refresh:
http://www.tigeowners.com/forum/show...hlight=taps+21
Never really figured out why it didn't work well. Maybe I just didn't play with it enough. Anyways I ripped it off the boat and sold the system and never looked back. My next boat was an MB F24 that wouldn't get out of it's own way at our elevation. I didn't even bother messing with that boat too much. We ran a surf shaper and was happy enough.
Fast forward to today. We have a boat we love and one that is finally a keeper. I started hearing a few rumors about how well GSA tabs were doing on the RZX boats in place of the TAPS3 tabs. So I decided to build my own version. Basically the same with a few tweeks.
Cole (bsreid) was nice enough to send me a few measurements of the GSA tabs he just picked up and installed on his RZX3. He tells me he is more and more impressed with them each time he gets his boat out. With those measurements I was able to start drawing up what I thought I wanted. I ended up making a few changes down the road.
I then printed everything out and mocked them up on the boat. This way I can check sizing and make sure I drew everything up right. This was a lot harder to do this time because of the 3D shape. So far so good.
I knew that I wanted to use the existing screw holes from the TAPS3 tabs to mount the new tabs. So I took careful measurements...and what goofy measurements they are! Also worth noting is that they are not the same on each side of the boat. They actually mirror each other. In all my work on these boats I have come to conclude that a lot of stuff seems to be kind of eyeballed when placed. Not very exact. So any time you're working on stuff, never assume a measurement or symmetry between sides.
With the screw holes measurements I was able to draw out a template for the hinge. I just cut these papers out and taped them to the hing. Then center punched and drilled them out.
