Overhead Courtesy Light 2017 E Tower
    I installed a Lumitec LED Courtesy Light 45mA 12V on 2017 Z1 Tower.
    I connected to the Blue/Yellow stripe wire and Black wire that were in the compartment at the top of the tower.
    Light does not come on with Touch screen...all other courtesy lights come on.
    Is this something that has to be dealer programmed in or do I need to trace wires under console?
    Thanks.
    is the mood light icon on the touch screen under switches?
    Oh Yeah!
      On touch screen I have Courtesy, Navigation, Tower and Anchor
      There are a couple switches that are grayed out and I believe those say mood lighting and dealer programmable.
        Go under dealer settings, code 9191 and enable "mood lighting". Then it won't be grayed out and you should be good to go.
