I have 2 Wetsounds Rev-10 tower speakers with all mounting hardware and beauty collars for the Alpha Z tower. $800 and I will only sell them as a pair.
Wetsounds Syn2 700 Watt Amp-$300
I will sell all of it together for $1000.00
Information on the amp is below. I changed my stereo configuration and no longer need these. They all work great.
The SYN2 is a high powered 2 channel class H amplifier. Because of it’s class H power supply and forced fan cooling system, the SYN2 can operate at 2 ohms stereo without any heat issues typically found in conventional amplifier designs. Giving you multiple configuration capabilities. The SYN2 is matched to run tower speakers in a pair of two pairs and is also an amazing subwoofer amplifier.
Specs
Stereo @ 4 Ohms 200 x 2 watts RMS
Stereo @ 2 Ohms 350 x 2 watts RMS
Mono @ 4 Ohms 700 x 1 watts RMS
s/n ratio @ 1 watt > 92 dB
Frequency Response 10 Hz - 50 KHz
Transient Distortion < .01% @ 4 Ohms
Input Sensitivity 0.6 V - 6.0 V
Input Impedance 20K Ohms
Bass Boost +15 dB @ 45 Hz
Crossover HP/LP 55 Hz - 550 Hz
Dimensions Inches ( L x W x H ) 13" x 8" x 2 3/8"
Specs
