I have 2 Wetsounds Rev10's for sale @ $800 for the pair, and I will only sell them as a pair. I have all the original mounting hardware and the beauty collars for the Alpha Z tower. The collars can be painted to match your tower.
I also have the Wetsounds Syn2 700 Watt amp for sale, @ $300
I changed the stereo configuration on my boat so I know longer need these. They work great!
If you would like to purchase all of it, I'd be happy to make a deal, please message me.
Below is some information regarding the amp.
The SYN2 is a high powered 2 channel class H amplifier. Because of it’s class H power supply and forced fan cooling system, the SYN2 can operate at 2 ohms stereo without any heat issues typically found in conventional amplifier designs. Giving you multiple configuration capabilities. The SYN2 is matched to run tower speakers in a pair of two pairs and is also an amazing subwoofer amplifier.
Specs
Stereo @ 4 Ohms 200 x 2 watts RMS
Stereo @ 2 Ohms 350 x 2 watts RMS
Mono @ 4 Ohms 700 x 1 watts RMS
s/n ratio @ 1 watt > 92 dB
Frequency Response 10 Hz - 50 KHz
Transient Distortion < .01% @ 4 Ohms
Input Sensitivity 0.6 V - 6.0 V
Input Impedance 20K Ohms
Bass Boost +15 dB @ 45 Hz
Crossover HP/LP 55 Hz - 550 Hz
Dimensions Inches ( L x W x H ) 13" x 8" x 2 3/8"
Specs
