Don’t go nxt they’re awful. I’d go r23, older Z3, or Fi23. Not really a huge fan of the Moomba but they’re definitely a step above axis and the nxt series.
New purchase advise r23
Couldn't agree more.. The NXT shouldn't even be a choice. Looked at those too.. I am even coming from a mastercraft X2 and the NXT was dropped off the list immediately. It shouldn't be called a mastercraft. Quality was there, but so basic it reminded me of my first Bayliner. Axis is another one to avoid IMO. The two i looked at looked like they were slapped together by a 4th grade art class. Like i said before, for the price,value and style, moomba and Tige are leaders i think.
Originally posted by wired1236 View PostHa! I’ve been warned that 500lbs spread up front is generally needed if you don’t have a large crew. Lead is cheaper than heavy guys that drink beer (in the long run). I think that’s true with most 22-23 footers from my reading.
Originally posted by bsreid View PostDon’t go nxt they’re awful. I’d go r23, older Z3, or Fi23. Not really a huge fan of the Moomba but they’re definitely a step above axis and the nxt series.Germaine Marine
Tigé Expert
- Oct 2014
- 1252
- Great Faces, Great Places--South Dakota!
- Used to have gangsta lean 24Ve; then GSA F24 Tomcat, now a 2016 Supra SE450. Onward we roll!
Originally posted by elevatedconcept View PostFI is a junk heap rattle can. Just being honest. I would take a Moomba Makai over that boat 10 out of 10 times.
Sent from my iPhone using TapatalkTime flies like an arrow; fruit flies like bananas!
To the OP, it just hit me. If you are planning on adding a heater plan on spending a bit more as you SHOULD get the inline pump to help pump antifreeze to heater and back to block. Only way Id go without it if the heater core got mounted in back close to the engine and even then I dont think it is worth risking and would personally still install the inline pump.
Originally posted by freeheel4life View PostDakotaAce is apparently stoked on his Makai, but not even sure what their price point is.
Originally posted by BurnMac42 View PostI was hoping we would start to get some input on the Makai on this forum. That boat definitely has me intrigued considering the very first one sold was reportedly heavily optioned out and went for $106k. With the R23 starting at 95k for me it's tempting enough to jump brands eventually which sucks because I love Tige but that's a lot more boat (literally) for your money...Germaine Marine
Originally posted by freeheel4life View PostTo the OP, it just hit me. If you are planning on adding a heater plan on spending a bit more as you SHOULD get the inline pump to help pump antifreeze to heater and back to block. Only way Id go without it if the heater core got mounted in back close to the engine and even then I dont think it is worth risking and would personally still install the inline pump.
Originally posted by wired1236 View PostInteresting idea. I never heard one being needed but I guess makes sense.
Originally posted by freeheel4life View PostIts a standard on every Raptor Ive seen from the manufacturer when equipped with a heater. Its aluminum heads and a cast iron block. I believe Indmar was super concerned with even temps throughout the heads to prevent any warping at the firing deck. Running without an inline, especially if core is up at helm and you are bow high when surfing could result in low coolant flow GPM. Thats just my take on it anyways.
Anyway- All in all, props to you for pointing it out and to Bjornson for stepping up and making things right.Thanks!!
