Sorry to start this already but as the summer starts to draw to a close I am thinking of shrink wrapping the boat this year. It looks fairly straight forward with the perimeter band and belly bands and some vents. My question is will a hand held electric heat gun work? Im sure it would take a lot longer but $40 versus $600 seems better to me for the gun? If anypne has done this please weigh in and let me know your thoughts?
Shrink Wrap
Originally posted by maxpow View PostSorry to start this already but as the summer starts to draw to a close I am thinking of shrink wrapping the boat this year. It looks fairly straight forward with the perimeter band and belly bands and some vents. My question is will a hand held electric heat gun work? Im sure it would take a lot longer but $40 versus $600 seems better to me for the gun? If anypne has done this please weigh in and let me know your thoughts?
Also you are missing a handful of other things in your list if you want to shrinkwrap. Desiccant being right at the top of the list. Also, P tape for seams. Pre wrap for banding lines. Theres a bunch of other things that are fairly critical as well process wise or you end up with a moldy boat when you unwrap it.
Or if you have 4 hours to burn you could go the electric route.
I only paid $250 to have my tige wrapped last year to travel from wisconsin to utah. iirc in 2013 it was only $300 from Freeheel's business to wrap it to get to wisconsin from idaho. don't remember what that cover was made of but I kept that one for 4 years and used it as a winter storage cover as it was a different type of wrap that had felt on the underside.2012 22ve.. RIP 4/17
2014 Z3.. Surf away
Originally posted by sandm View PostI only paid $250 to have my tige wrapped last year to travel from wisconsin to utah. iirc in 2013 it was only $300 from Freeheel's business to wrap it to get to wisconsin from idaho. don't remember what that cover was made of but I kept that one for 4 years and used it as a winter storage cover as it was a different type of wrap that had felt on the underside.
Originally posted by maxpow View PostIf it was $250 to have it done here id pay that but last time I looked into it it was just over $500 for my 22v.
If you want to do it at home I'd be trying it with a weed burner instead of electric heat gun personally.
https://www.homedepot.com/p/Lincoln-...FQoXrQYdB58OBQ
^^one of these hooked up to a regular old bbq propane cylinder. May be worth wrapping something small like a cardboard box first to figure out how much heat and speed you need.
If you go for it be sure to get some desiccant. Make sure the boat is really dry before shrinking or it will mold. No wet gear inside either or it molds. I know that sound like a no brainer but you'd be surprised how many guys go out for their last day and want their soaking wet 3 person tube and life vests shrink into the boat because they dont qant to see them in the garage.
Good luckAttached Files
Originally posted by freeheel4life View PostDang. I wouldnt pay that much for a 22' boat either. These sailboats are much larger than your 22v and got them in at around the same price you were quoted to shrink your boat. Either I'm undercharging or your local shrink shop is making a killing.
Good luck
Originally posted by maxpow View Postwith that weed burner do you think you could squish the end of it so it would fan the flame out wide like the gun?
Originally posted by freeheel4life View PostMaybe. Im no expert but I think part of the tips design on the weed burner is the holes on the backside drafting air to "shoot" out flame. Choking down the tip may restrict that air flow. If you got the weed burner going so that it had a good steady "jet" sounding flame but not full blast and then just made sure to keep it moving(dont linger in one spot on the shrink with the heat) you could probably do it no problem.Oh Yeah!
Originally posted by KoolAid View PostJust buy the real gun and go into the shrink wrap bidness :-)
Originally posted by jeremiah.hough View PostDoes anyone know of a place in Missouri that does this? If not I would think lake of the ozarks would be a killer market.
