FYI, engine harness is on engine and ends at the plug near trans(Indmar built harness). The rest is the boat harness (Tige).
Indmar Recall: Catalytic Converter and Exhaust Y Manifold
Right on. Just didnt want you to try and order a harness and get the wrong thing. If you were to get an engine harness you would only get everything that is on the engine and it would end well before your pic. If you've totally given up on dealers there is a "break out harness" that you can get from Indmar where you can run the engine separate from the boat. Could help isolate problems if you truly believe it's on the boat side.
If you really wanted to get nuts I could probably help you build your own harness to run the engine without boat side plugged in though it's on trailer only diagnostic tool. PM me if you want to try that.Last edited by freeheel4life; 08-23-2018, 04:27 AM.
