Could X-over be causing bags to fill?
    I added an impeller Jabsco pump with 1" lines as a crossover to my setup last year. My existing ballast has 3/4 inch lines and aerators. I am now experiencing one (usually only one) of the rear bags taking on water when the boat is docked or just floating. Could this be because of the newly installed cross over system? I'm not sure timing is exact but it never used to do that.
    2008 Tige Z1 Limited Ronix Edition
    360 hp, Fly High ballast, Alpine, JL Audio, Kicker, Wetsounds audio
    not unless the other side is full and you find it not full. Likely need to rework the fill line.
