mchirpich hooked me up with his old FAE that had just been rebuilt to new last week and I quickly put it to good use. Its intended use was on a Z3 but after checking with FAE they told me this would work on my rzx. Really the only guess was if it would reach around the TAPS plate. Ended up clearing by about a 1/4". Perfect! I was originally planning on removing the welded on flange and adding material to the "intake" end and then welding on a new flange so that it would resemble the newer style (less mandrel bends) intended for the rzx's, and then not using a support rod. Well then the Mrs decided to destroy one of our garage doors last week, so there went the funds. This ended up getting put on for as cheap as possible.
I drew up and CNC cut a new support bracket out of 3/16" stainless then spent a bit of time polishing it to match the polish job of the TAPS hinge... just short of mirrored. I then just needed to shorten the support rod that came with the exhaust. I'm very happy with the finished product and even happier with the overall price: a grand total of $324. I think the new ones are about a grand from dealers ???
This being the first FAE I've had in my hands and really getting to look at it, I'm once again a bit disappointed with the build quality. I have expressed disappointment in the past about weld quality I've seen from pictures, and this one is no different. In the end, I think I'm glad I kept the support rod as I don't think the welds could support the stress on their own, hence the move to mandrel bent tube. The little tube they "weld" on the FAE for the support is just hideous. Why not just machine a very simple part that fits the tube right and makes for a nice weld? Speaking of welds, I noticed they didn't back purge the SS tube when they welded it. This causes the weld on the inside of the tube to oxidize. Oxidation allows the weld and the tube around the weld to rust. So at least mine and probably everyone's are getting eaten up from the inside out.
My first bracket's neck was 1/2" too long. Measure twice, cut once right? Anyways it shows my attempt at polishing. I have very little experience polishing parts. Turned out well enough.
Tomorrow is the big test. I look forward to the boat running a bit quieter. Thanks again Mike for the good deal on the FAE!
