Help with 2004 22v Rider warning alarm going off and engine stalling at idle
    Had the boat out surfing and the alarm would go on for a few seconds after about 20 mins on the water and then go off. A little while later it would do it again. Sometimes for a few seconds and others times maybe a minute but always went off. Then its started to die when i went to neutral. Intially it started right back up and would run fine but then occasionally die again when going to neutral. After a few times of this when I went to restart it would struggle almost like it was flooded. We also smelled a stronger gas smell at that point. Any ideas would be appreciated. No Tige dealers in my area so sometimes need to point local marina in right directions. Thanks!!!
