Taps3 actuator initial set up
    Good morning. I changed my port side taps3 actuator yesterday and just wondering if there is a specific setting in the dealer mode I need to have the boat set at.
    When I was diagnosing the problem I definitely changed a bunch of the values in the surf demo page for >surf =surf <surf trying to get the plate to move.
    What should the values be set at before I exit the page? Thanks!!
    B
    They do not impact what happens when you exit dealer mode - and use when you use your taps 3 to surf. I believe they also reset upon exit from dealer mode.
      You are good to go. Exit and you are fine.
      Germaine Marine
