ballast question
    ballast question
    I am going to install a ballast system for next season over the winter in my 05 22v but I am starting to look into it now. My question: Is it better to have each individual pump with its own thru hull or will I get good results with a manifold to feed the fill pumps? Are reversible better less space is used less holes, is the fill time drastically different from an aerator. I have lots of questions before I do this so be prepared for more to come lol.
    The pump to thru-hull ratio is less important then the flow rate of the inlet plumbing.
    A typical aerator pump can drop 20-25% of its rated flow rate, by time the water hits the sac. Impeller pumps are less effected by head pressure and maintain there rated flow rate.
      So an 1000 GPH aerator will be close to a 750 gph impeller is what your saying? if I go with a manifold could I just use a large diameter thru hull then to make sure the manifold stays full then and as long as I fill one bag at a time there would be no issues is that safe to say?
        Another thing I have 800lbs in each side compartment beside the engine and i have 500lbs in the bow that i will plumb in will this be enough for a good wave? 2100lbs plus people and a suck gate???
          Maxpow,
          I have the same boat and am here in Lethbridge as well. I would be happy to show you the system that I installed a number of years ago as well as the wave that it makes and then you can make some decisions. PM me and I would be happy to show you the boat and system.
            Maxpow,
            I also have the same boat as you and did my own ballast install last year. I did a write up with pics of the install. I think you will find it helpful. Search and if you can’t find it let me know. PM me if you have any questions. Chpthrll was a big help. I, like many others, bought the kit from him and his phone support was invaluable.
            My setup is as follows:
            Qty 3 x 750 GPH Johnson Impeller pumps
            Rear bags: 1100 lbs each
            Front bag: 600 lb under the seat bow bag.
            I did 3 separate thru hulls. It was a tight fit tho and if I did it again would think about doing 2.
            Fill time on the 1100lb sacks with my config is about 8 mins. 600 lb sack in about 3-4 mins.
            The wave is pretty good. We surf mostly goofy and use a suck gate. I’ve determined I’m a little light in the bow with this config and just started adding about 300lbs with a sac in the bow walkway I borrowed from a friend (total PIA to fill and empty with the thro over pump). You’re shooting for a 60/40 ratio rear to front. I may consider some lead bags for next year.
            PRO TIP. Consider buying rear sacks with a sloped front end to better fit the rear compartments. I feel like my sacks are a tad oversized and end up filling in a less then optimal fashion around and underneath the rear seat area.
              Originally posted by macteacher2 View Post
              Maxpow,
              Thanks so much id like to see the set up and how you did it. i have an idea but until i see the pumps i wont know what i can/cant do. if your around saturday in the morning maybe we can meet up?
                Originally posted by skiguy View Post
                Maxpow,
                good info thanks i will check out your install! i have the round 800lbs straight line bags for the rear and I have a 750 for the bow but i really dont think i will be able to fill it more than 500. That being said i dont even know if i can make it fit under the seats so i was planning on getting a 500lb straight line bow bag. I think i will be doing the same pumps as you, I was thinking about a single thru hull and pulling from a manifold as i did wonder about space as you mentioned. But i do wonder about filling multiple bags off a manifold is it possible or does it have to be one at a time?
                  There is some science here around calculating flow capacity based on the size of the opening vs pump capability. If you go with a larger than standard thru-hull you should be ok with those pumps. It won’t fill or drain quite as fast as dedicated openings per pump but I suspect it’s not a significant difference.
