Will this pump be an effective replacement for my crank driven raw water intake pump? I have a 2005 Tige 22v with 5.7 mp 340 with Johnson crank mounted pump. My pump is leaking out of the rear seal and need to replace it. It said on the ad that it needs to attach to a steel pulpy not cast iron... I’m assuming mine is steel? Can anyone help me out since I don’t want to remove the old one until I get the new one and it’s hard to see back there.
Thanks,
Sam
![](https://uploads.tapatalk-cdn.com/20180715/1cdb900c7f43d6e16dbc74bbe6788956.png)
Thanks,
Sam
