I know this should be in the technical section, and it is but under another topic. I posted here to get maximum exposure to this problem. I've had a leak somewhere since we got the '95 2000slm comp, I found the leak all right, it's a cracked head. The leak only shows up when above idle and with a load on the engine. here's what i posted in technical;
I wish it was a freeze plug! I pulled the exhaust manifold and cleaned the side of the head real good and watched water seeping through the casting in two places between cylinders 2 & 4 along a line i suspected was a crack.
We took it out Sunday to find the leak and up until then it has run perfectly. Sunday however was different, it didn't want to start and when it did finally start it ran rough until i got going a bit. Then it quit after awhile like it was starving for fuel. If i let it sit it restarted but wouldn't take a load so i had to idle in to the marina. What bothers me is that when it did restart it blew pure white smoke out the exhaust which i suspect was steam from compressed water in a cylinder.
The funny thing is that it ran perfectly smooth at 10 mph without any hesitation at all. I'm going to pull the head Saturday and see what's up inside. From the outside looking through the exhaust ports the valves look good with no sign of water so who knows. Also you should never do just one head so I'll end up having to do both if the block is ok. Oh well such is life huh? My super deal may not be so super after all! The wife is bummed and stressed over this ... sigh
I'm debating on replacing th head, finding a low hours used engine, rebuilding mine or ? Any thoughts?
