My taps gauge on the dash isn't working. Stuck at #1 position. The taps plate moves up and down if I hit the switch but have no way to know where the setting is. Any ideas what the problem would be? Wasn't sure if it would be the gauge or if it was a relay, etc.
It happened after I did a calibrate on the TAPS system. The gauge started going top to bottom and stopping all over in between. This went on for 20 minutes before it quit. I assume it damaged the system but no sure what part.
Boat is a 2012 Tige RZR.
Thanks
Thanks
