20v instrument manuals
    Where can I find a manual for the speedo and tach instruments on a 2007 20V (Medallion guages). The documents on the tige owners page are only picutres of the set-up - no info on how to toggle between oil pressure, temp, depth, speed, etc.
    There is no way to toggle between the functions on the gauges. They are etched in the glass. Only the numbers change next to them.
    http://tigeowners.com/downloads/Tige_OM_web.pdf
    Page 4-9 covers the gauges.
    Oh Yeah!
      Okay - I thought I saw something about being able to pull other readings up. On my tach guage, the three listed are set, actual, and depth - they look more like LED - not ethced. The "set" goes away if I don't have a speed set, so appears not to be etched. Question is, why do I have "depth" on the bottom? I think it should be hours, and I have depth on the speedometer. The number reading next to depth appears to be the hours on the engine, not the depth reading - just the wrong title. Anyone seen this before?
        Do your gauges look like these? If so, the only time I see set, actual and depth is when the Tige speedset is turned on.
          I believe mine has depth, volts, and hours when the speedset is off
            yes - mine look like that. attachment is from the only thing close to a manual I can find. I thought I remembered seeing volts, etc in there, but now can't make anything come up other than as shown, with the exception that "hour" says "depth". Your set and actual goes to a different display when speed set is turned off? Do you have to do anything for that, or just turn it off?
              Ok, the difference is in the dash for the different model boats. The picture above has the lcd display in the center which changes with the speedset where yours has the analog gauge cluster.
