How does the surf number change the wave TAPS3?
    go see the thread labeled "2017 Z3 Surf wave and prop". Elevated's post there was the key to dialing in our new r23 wave (thanks! @Elevatedconcept). it's the same hull as the Z3.
    bottom line(s):
    add weight (lead) on rear lockers. we are running 450# lead each side and it's an awesome wave. That hull likes junk in the trunk.
    i also found that listing slightly to surf side cleans and powers the wave a touch more than running even, but dont do that if you're doing transfers.
      For boats that have TAPS3 do you still want to shoot for around 6 degrees of list or is the list less important when you have taps3?
      Thanks
