Anyone with a 2015 RZ or Ve, doesnt matter 22 or 24? Curious about the drop between rear lockers and the seat storage area. How much is the drop? Like in the 5-6 inch range?
Closer to 2" to 3". On the tank and bag combo boats. the floor sat 2" or so taller in the back than the rest of the floor. On the bag only models, that section of the floor sits about 2" lower than the rest of the floor.
Am I answering the question properly? Just want to be sure I didn't miss anything.
Your are, thanks. This boat seems to be a tank/sac combo Surf/Pro ballast setup, but the locker floor is 5-6 higher then the seat cavity floor. Thats greater then ive ever seen on any tige model.
