Well I talked to the previous owner last night and he said he had similar issues with the boat and it was the distributor cap. I have had problems with a previous boat but the boat would run just not good so I didn’t even think to look at it. Went to parts store this morning and got a new cap and rotor button. When I pulled the old cap off I became a believer. I have never seen such a mess under a dist cap like that. Swapped them out and reset power and it fired right up. Only let it run for a few seconds since it was t hooked up to water but it didn’t die out! Going to put it in water after work for a real test! Fingers crossed !
2007 RZ2 MP 340 Starts and immediately dies
Originally posted by bamaboy2006 View PostThanks for the reply. The butterfly valve doesn’t move when the throttle is engaged and I turn the key over.
Marine Power (Eddie) - 985.386.2081
Originally posted by bamaboy2006 View PostWell I talked to the previous owner last night and he said he had similar issues with the boat and it was the distributor cap. I have had problems with a previous boat but the boat would run just not good so I didn’t even think to look at it. Went to parts store this morning and got a new cap and rotor button. When I pulled the old cap off I became a believer. I have never seen such a mess under a dist cap like that. Swapped them out and reset power and it fired right up. Only let it run for a few seconds since it was t hooked up to water but it didn’t die out! Going to put it in water after work for a real test! Fingers crossed !
Don't get me started on the factory ignition components, they are absolute junk.
