I bought a set of 4 about a month ago and I honestly was not sure how much I would use them since I rarely do tie-ups except when my brother and I get our boats together. I have already used them a half dozen times and can say I am very pleased with them. Easy to blow up with my onboard compressor, don't leave marks on the boat and do an excellent job of keeping boats apart or docking and I like that they fit over handle so you can thread docking line thru it, it tie to middle. Only 2 suggestions I would make are:
*Have a couple extra plugs on a set of 4, since I am sure those are gonna be easy to misplace.
*Removing the plugs when they are fully inflated can be a little bit of pain, I usually use my teeth, lol. Dont know if there is even a better way, just mentioning since I know you are trying to make these the best ballz out there.
Not complaining, just making remarks. Good buy and I would do it again. I have actually put you out there on several forums, I keep forgetting to take pictures since I know you want as many as possible as you launch this. Wishing you the best of luck making this bigtime.
Thank you for the kind words. It is pretty funny how much you end up using these. I honestly now don't carry any other types of fenders.
I love hearing feedback like this!. When I receive the shipment of extra plugs, I'm going to start including extras in each shipment. The plugs can be a bit tough to get out. I'm working on a solution for this now. And yes I definitely want pictures!
For anyone browsing and wondering if you should get these DO IT! they are awesome. hands down best boat bumpers I've owned and already protected from a couple of dock dings, they don't mar the gelcoat, they flex, they keep the distance, they deflate for easy storage, etc...
A couple of other use tips, fwiw,
i tied a short line on the handles to loop them up and through the pull up cleats, esp when fully inflated helps keep them on if going for a quick run across the lake
I don't put plugs in all the way and leave a little edge out so i can pull them out to delflate.
i was using a 12v inflator, but just as easy and quick to just use your lungs, though I can't get em quite as full that way
An awesome product.
Thanks for the feedback! I'm glad you're liking them! I actually leave the plug a little ways out as well. I didn't even realize I did this until I saw your comment. The plug defiantly doesn't need to be pushed in all the way for it to stay in with no problems. Although I have plans to include some kind of tool with each order. It's just one more thing to lose! But the ones I've used so far really help. I'm probably going to put it on some kind of quick release key chain. That way you can pop it off easily without removing your keys from the ignition.
I bought a set of four a few weeks back. Have not got them to the new boat yet. I was looking for a small rechargeable air pump so I would not have to dig out the big pump every time. I ordered this off of Amazon:
I have only used it off of the water so far to test the pump. It takes less then one minute to blow up one ball. the pump blows it up firm enough to allow 120 lb girl to sit on the ball. Picking up the new boat tomorrow and will test over the next couple of weeks. The pump is really small!!. If you order one, you must charge it with the switch off. The switch is not labeled. Off is up.
