Ok, sorry for the stupid question. I took my boat out of winterization today. i wanted to fire it up and make sure it was running ok. I have a sea strainer so i just hooked my garden hose to it. i turned it on and fired it up. It started great and the first thing coming out the exhaust was the pink anti-freeze i put in last fall. Everything seemed fine then i noticed quite a bit of water coming out around the drive shaft. How much water should come from around the shaft? I called my dealer and there are of course swamped but he said there should be some water coming around the shaft to cool it. i did notice even when i turned the water off some water continued to drain from it. I did a quick visual from the underneath and didn't see anything obviously wrong. I guess the real test will be when i launch it the first time but i thought I'd check with you experts first. Thanks for any help. I will try to take some pics when i get back home Sunday. Out of town for stinking travel baseball.
