whole boat vinyl
    whole boat vinyl
    I am hoping that some of you out there can give me an idea of the cost to redo the vinyl for the entire boat. I have a Z1, so not as much as the big boys, but I am worried it will cost WAY too much. Honestly, I am only looking at labor costs at this point because I do not know what material I will use. I can only assume that I will not be able to match the materials of my 2013, so I am stuck looking at a total redo. Please let me know of any opinions, ideas or options. Summer is just around to corner in the north land, surf on!
    I paid $250 for the very front triangle bow cushion on my Z3. So... ha not good for a whole boat. They matched the silver and white exactly.
      I would say 3500 dollars as a wild guess for labor and materials. I think 65-70% of you bill is labor btw.
        Who did this for you? Will Tige send you new pieces? I have some areas I’d like fixed.
        BABz - babzusa.com
        Austin, TX
          3500 for labor sounds about right for a quality job with someone who is making the vinyl from scratch. 4500-5k all in would be my guess. Pick your shop carefully, a lot of hacks out there and you dont want crappy vinyl, or someone who does not know how to do it right. Its a lot of work to tear a boat apart and then put it all back together.
          If you had the time, you could probably save quite a bit by removing every cushion and taking to them....they replace and then you re-install it all. The remove and re-install is half the time on the job and time consuming. Just a thought
            Good call. The person I use gives me a better deal if I remove the staples and skins.
              I am looking at a custom shop for the work and of course a higher price for quality-which is what I want. I assumed I would take pieces out and deliver them for repair to save some cash. Most of the vinyl is still in good shape. Bad stuff does not match the new current materials available. Do you think any can be reused/restitched?
                I had a local upholstery/auto restoration shop do the work. He had a few books of samples that we looked through until we found the exact match to the different vinyls Tige used. The only way I can tell it’s not original when it is back in the boat is that he used the wrong color stitching, white instead of black.
                I’ve read on here Tige will well you new skins to a certain year back based on your HIN, I’m planning to go that route for my next pieces. I doubt it will be as easy as swiping my card at the upholstery shop, but I’ve got anpnumaticnstapler from doing motocross seats so we will see.
                As far as replacing only certain sections, the upholstery shop did say that could be possible. Much of my silver vinyl has separated (2013) and he made it seem possible to just replace That chunk rather then the entire cushion cover if the other parts are still in good shape.
                Apparently a lot of used car dealers have him replace just the side of the leather seat that gets wore out on used cars quite a bit. He said they rarely do the whole seat, just replace that one outside section.
                  Tige sells the skins to make it simpler. I do not know how far back in years they go. This is the best option as they will be made correct.
                  Then your upolstery guy can do the rest.
                  Wake Up or Stay On Shore!
                    Have you ever seen a reskin on an older boat with old foam? Yeah its horrible. Maybe for some its ok, but the avg joe would think the seams and stuff look terrible. When you have to start pulling the re-skins that were built and made to go over new foam over old stuff it ends up looking god awful from a lines perspective. You need to start over if you are spending the money. To go completely new from Tige for upholstery, z cline and Dash's etc, complete with Labor is around 8-10K. But im talking dash's whole new Z cline etc
                    Germaine Marine
                      Tigé sent me a new observer seat skin. It looks like new and was reasonable in price. I'd contact them and ask. They might give you a discount since 2013 was a problem year. I'll send a pic when I get home.
                      My boat is a 2013 Z1 also.
                        Thanks for the input to all. Tige has offered to send me material only, not skins. Sooo I am stuck with the decision. The new material does not match the 2013, and they are only offering three colors. I have areas that have four different colors/materials. I am not interested in spending 7-10g to have this done, but I am not blaming Tige at this point either. My boat is out of warranty and they are willing to consider something. JohnieMo, can't wait to see your pick. Elevated concept, your suggestion to re-foam as well sounds like a good idea.
                          Here are pics. This is a skin that a local shop installed for me. Total cost was about $350 CAD.
                          It seriously looks like new.
                            BTW if Tige is only offering materials, just go aftermarket. The shop I used told me he has access to all the materials above. So unless your boat had something really freaky I expect this is all do-able.
                            If it were me, I'd go with a simpler design as this design is more likely to fail eventually. I'd also do it all in one place and hopefully get a discount.
                            It sounds expensive but it is still a lot cheaper than a new boat.
                              Which shop did you use? my seats are in great shape other than the silver in a couple spots. I would like to try and get the silver matched and just repair those pieces piece
