Looked at an Rz today. Buzz the 2 small beads off, retract fully while in dealer mode, mark the new location, tack it then lay a couple good beads down. Should take all of 2 hours max
Tige touch dealer settings
Originally posted by elevatedconcept View PostLooked at an Rz today. Buzz the 2 small beads off, retract fully while in dealer mode, mark the new location, tack it then lay a couple good beads down. Should take all of 2 hours max
That is an another excellent solution, I’m guessing that moving the mount that little bit won’t change the angle of the plate enough to adversely effect the wave. I know it wouldn’t be any different than any of the other solutions regarding changing the ram attachment angle or height.
The weird thing is the TAPS ram goes from 5 to 6 with 1 BZZZ, then 6 to 7 with 1 BZZZ, then 7 to 8 it does 2 BZZZ BZZZ, almost like it’s going to 9 even though there isn’t a 9 hits the pipe then goes back down. Inside the TIGE touch indicates 7 to 8, you hear the double BZZZ then it indicates 7 again momentarily then goes to 8. Hopefully that makes some sense, I probably sound crazy describing it like that. I’ll post a video of it next time I’m at the boat.
