Bought a 2000 21i recently and a new tow vehicle too. Took a while deciding what tow vehicle to buy so thought i'd give my quick impressions.
Ended up with an '05 Nissan Pathfinder. They come with a 4.0l V6 with 270 hp and I believe 280 torque. I'm located in Calgary Alberta and many of our nearer lakes are a nice ride through the rocky mountains.
Last weekend we towed it across a few mountain ranges and it performed reasonably well. Not sure exactly the weight on the boat and trailer but estimating the boat at ~3500 lbs and trailer at 1000 lbs. So a total likely at 5000 lbs with all the gear and fuel. Tandem axle roadrunner trailer. The pahtfinders are rated at 6000 lbs with a 600 lb tounge weight. Not sure what the tounge weight is exactly but pretty sure under 600 as a buddy and me can lift it relatively easy.
Were at 3500 ft above sealevel and the mountain passes went to likely 5500 ft. Some long steep sections and some very tight curvy sections too. Didnt feel out of control through the tight sections and it climbed nicely through the steeps.
Its a 5spd auto with very tight 4/5 gear. Gears down to 3 for harder spots and down to 2 you can climb pretty much anything with the whole rig at a decent speed.
Gas mileage on highways not towing is around 20 and I averaged around 10-12mpg towing through the mountains.
I could feel the brakes pulse a bit at the end of a long down hill run. Tail end drops more than i'd like so airbag suspension inserts might be a good investment, but not necessary - still want to get tounge weight. And I'd likely add a tranny cooler for those hauls throught the mountains.
Anyways, hopefully this helps someone.
Cheers, Jeff
Cheers, Jeff
