I have a 2013 RZ2 not that it matters for the question at hand. I have never replaced my batteries. It currently has 2 interstate batteries, towards the end of season one seemed to hold charge the other would not. The marina I store my boat will replace them at a hefty price, but i can do myself. They do not sale interstate at the marina. What are suggestions on brand and best place to order from?
Battery?
I prefer Intersstate.
https://www.interstatebatteries.com/...rch=birmingham, AL
Lots of dealers in your area. Deka or Sterling are decent too. Don't buy cheap Napa, O'reillys, or Duracell IMO. Some guys buy from Costco because of their crazy return policy. I say its not worth driving back and fourth from the marina to Costco to return them, and you will in a year or so from what Ive seen unless they get put on a tender during lay up
I use interstate int he shop, and have good success with them. With that said, any quality battery will serve you good if its maintained and serviced. Out of the interstate camp, you would want an SRM-24 and 24-XHD. Outside of interstate, you want a group-24 cranking and seep cycle.
Dont assume they are in the correct position when you pull the old ones out. Seen many with the cranking on the house side and deep on the cranking side.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Brianrzr View PostWhich side is which?
Don't know what year that became standard, but seems like after 06 that was the standard. Maybe it ws later. There is an odd model that has gotten me in trouble where crank batt is in port locker behind the seat and house was under stbd seat...if I remember correctlyLast edited by freeheel4life; 03-03-2018, 07:37 AM.
There's kind of a lot of hypothetical there based on application. In the case of your boat (and most others) running dual cranking batts isn't really a benefit. The advantage to the cranking batteries is a higher Cranking Amps capacity. The more compression an engine has the higher the amp draw when cranking. Unless you were running a very large diesel you would never NEED dual cranking batts wired in parallel. Now there's definitely an argument for running dual deep cycles, and in fact we have been running dual deeps in all our Skiers Choice boats for a while now.
Benefits of deep cycle is right there in the name. They designed to be discharged to a low state of charge and recover when current is put back into them. They offer a lower cranking amperage though.
That's why you have one of each. Chpthrll can probably give you even more info.
Originally posted by freeheel4life View PostThere's kind of a lot of hypothetical there based on application. In the case of your boat (and most others) running dual cranking batts isn't really a benefit. The advantage to the cranking batteries is a higher Cranking Amps capacity. The more compression an engine has the higher the amp draw when cranking. Unless you were running a very large diesel you would never NEED dual cranking batts wired in parallel. Now there's definitely an argument for running dual deep cycles, and in fact we have been running dual deeps in all our Skiers Choice boats for a while now.
Benefits of deep cycle is right there in the name. They designed to be discharged to a low state of chargr
In a setup like the tige where we have a clear cut dedicated house bank and dedicated c ranking bank, I prefer a cranking and a deep when running wet cell lead acid. Doesnt really matter with AGM. Although a deep cycle will crank an engine, I dont like for that to be its primary job. With a regulated alternator and a working VSR/ASR, i dont worry much about over charging a deep cycle while the boat is in use. Theres enough load that the the alternator is really just covering the spread, not just charging a static battery. Lack of or improper maintenance I think, is the biggest battery killer. Too many house banks get put away depleted. Spend the day at the sand bar hammering on the stereo, then a short 15 minute ride back to slip/ramp. Battery is still low when the boat is put away. Needs to be charged right then. Yes, I understand this is not always feasible for all. some dont have an on-board charger or access to 110AC where the boat goes. Sometime sits just a matter of having the time to do it, and 6PM on Sunday evening i snot, when the kids are tired and sunburned and the wife is fed up with your drunk obnoxious friends Every one just want to call it a day.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
^^Mike nails it as usual. Lack of maintenance/tending seems to be why I change out more batteries than anything. My favorite is the super swelled case. Most don't realize that the acid and water will drop out of solution when battery SOC gets too low. Then in our cold weather the water freezes and you can physically see it in the plastic case. Often will test for a bad cell as the plates short internally. Not all the time, but see it more than Id like. Some people will make no efforts to maintain battery how much you try to educate.
I guess with the constant charging thing, even with a VSR/ASR/ isolator it will always send some current to batteries right?? Otherwise it creates an open between batt and alt, and voltage regulator will spike and try to charge at very high voltage(high field current) ya??Last edited by freeheel4life; 03-05-2018, 06:11 PM.
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
CHPthrl is right as usual. For the OP question, what he said.
I think it is also important to consider what your system is set up like. If you have an older 1-2-combine switch, without a VSR, then I prefer getting identical batteries. When you are in combined mode, the batteries are combined when both charging and not charging and are constantly transferring power back and forth, which will kill one of the batteries prematurely if you have batteries that are not the same.Be excellent to one another.
Originally posted by Brianrzr View PostHas anybody installed a "Blue Sea Batterylink 10amp Charger #7605"? I know many factors are involved, but on average, how long does it take an Indmar to recharge a battery after 1,800 watt amps at the sandbar for an hour?
As to the alternator. How long to recharge after an hour with an 1800W amp is like how long to get to LA with a 450 HP engine. Advertised AC wattage outputs of an amp are unreliable to use for finding the amplifier's DC amperage current draw from a battery, because there is no real formula for using the AC watts to get DC amps. This can be estimated at best, as music is so dynamic, its hard to get a constant. Lastly, it will take way longer then many think, for a typical alternator to recharge a dead battery.
IIRC, your engine has a 90A alternator. The integrated ACR in the charger is rated for 65A. FYIMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
