So noticing a couple changes that won't make it into marketing material that I thought I would post.
Hard to tell but the holes are at rear seat so water can drain. Still doesn t get drainage into the bilge (will drain onto L bags or carpet if bags are folded) but at least it helps get water out of vinyl. Noticed it was just holes drilled before, now it seems like the same grommets that are in the center tray over engine are inserted for a much cleaner look.
The cool bypass panel is in front of helm on starboard side just above heater. BTW panel pic is off by 90*. Allows you to empty ballast, run bilge and blower, and turn on nav lights should touch screen go down. Great feature. This is on a 18 z3, not sure if 18 R series has the same panel. I tend to find stuff by necessity so here's what I've found so far.
COOL functional tweaks that don't make it into ads next to bigger screens and wheel controls.
