Props for 2017 Z3
    Props for 2017 Z3
    I was looking for prop to replace factory when i first bought my boat , i cant find that thread anymore. Please advise me again on prop upgrade , i know chpthrll sells them . In ga, little to no elevation really. I will have 700lbs lead plus full rear sacks. 50 in the fronts.
    If you wanna know what I did , come with me next time...
    What prop do you have? I don't think there is an across the board standard, ours came with the right prop for our altitude and heavy surfing, it's an Acme 2419. I'm close to the same solid ballast as you, I run 100% front and back, and I can still yank someone pretty hard if I don't ease into the throttle taking off.
    Knowing how hard it pulls at our altitude (5000 ft), I'm guessing you could probably get away with using something a little less aggressive to get lower RPMs -- I only managed to average 6 gallons per hour.
      2315 would be plenty at no elevation.
      Germaine Marine
        Thanks guys
