Ya, going in on almost 1k worth of reversibles right out the gate is a bit hard to chew on plus new thru hulls and hose. Just think though you could be 6 to 7 minutes off the lift
. Really don't think it would be that hard though as far as skill. You would literally just have to crimp on two Duestch pins for each pump and stick em in the PDM connectors until it click into place. Don't even have to de-pin the connector. I say that all now after never having done it though. But the pumps are just behind carpeted panels at transom. Three whole screws to access them and the PDM. Drill out three new thru hulls and run your hose. Not a super tough install I would think. I imagine you are not running huge bow weight either so you could probably add just 2 for those 1300s in the rear. Just thinking out loud...and its always easy to theoretically spend other peoples money.
