2007 tige RZ2 Pictures
    Here are some pictures i took from work
    http://www.wakepics.com/img/20269
    Side Shot^
    http://www.wakepics.com/img/20270
    Hull^
    http://www.wakepics.com/img/20271
    Front^
    http://www.wakepics.com/img/20272
    Back^
    http://www.wakepics.com/img/20273
    Sitting^
    http://www.wakepics.com/img/20274
    Cockpit^
    http://www.wakepics.com/img/20275
    Ballast Switches^
    http://www.wakepics.com/img/20276
    Engine^
    http://www.wakepics.com/img/20277
    Ballast tank and storage^
    Very cool, thanks.
      Is that the Slalom Shop pro shop boat?
        1. I did not realize so much of the storage space would be taken up by the ballast tanks. Thumbs down.
        2. Is that a Simer pump? My buddy has replaced his twice on his brand new boat since July. another thumb down. They seem to be much less reliable than aerator pumps from what I have heard. How do they do the intake and discharge? Do they have the intake on the back of the boat so that you cannot fill while running? I think that I'll have to lean to another Rival install if that is true...@#$%!^
        3. With the tow rings below the swimstep, where are you supposed to attach a tuber, the built in the fiberglass ski pylon or the tower?
        4. I thought that they were going to a U bag in the front, but I notice that there are 2 switches for the front, please clarify what is up there.
        5. They came out with that sweet new mesh driver's seat and immediately no one can have one?
        Be excellent to one another.
          Tall,
          I'm pretty sure that's only on the side where the batteries are... I'm with you and think I would look to Rival again.
          w/o the tanks, I'm hoping they tuck the taps and battery back in the transom.
          I often anchor off the front and back of the boat... not sure how that would work for me now.
            Tigé is using aerator pumps on the ballast with two for the "u" bag.
              The are 2 hard tanks in the back with there own pumps and 1 "U" sac in the front with 2 pumps
                update... The both compartments look like above.
                Off the subject. I saw an '07 22ve and 24ve today. The new dash is sweet.
                  On the picture of the engine, you can clearly see the pump on top of the ballast tank...it is not an aerator type pump...Maybe it is the shower?
                    Originally posted by Lucky 275
                    Tall,
                    your right, its only on the side where the batteries are. i looked at mine today and i dont have the ballast installed yet and the batteries are in the back, they move them foward and then puyt the ballast behind it........at least the rear is not a seperate storage, underneath theres room through too all the seats!
                    CIH/pcrew founder
                    SWP Video Mag co-owner/rider
                      Yes, that is the shower pump. You can not see the ballast pumps in that picture.
                        I rode behind the new RZ2 W/ stock ballast and it was sweet a bit longer then last years wake and with ballast and taps a lot bigger with a peak at the end of the wake that bucks you up...all in all sweet boat sweet wake
