Hey guys anyone know how to get some great wake weighting a 2001 tige 20ci. I'm a new owner and newer wakeboarder looking to correctly weight my boat to get better air and pop off of my wake. Also, does anyone know how to use the waketower racks. I can't figure those dang things out. Thanks for your time.
How to weight a 2001 Tige 20ci
I have 03 20i. here is how i run weight when I weight up (or should that be down?) 600 in the bow walk thru (get it as far forward as you can). 350 vdrive sacks on each side of the engine box. it will give you a sweet wake......be careful when you back off of the throttle if you do it to fast you can dip the nose. also make sure you back down let the wake pass and then turn around and pick up you rider.
Hope this helps and good riding to you.
