Yeah man making countertops shelves and brackets all day every day lol
2001 23V rebuild from the ground up
Thanks Guys!
CM,
That's not the final color, once it got oil it darkened way back up. I would prefer it stay that color but the Iroko used is just a dark wood by nature.MVIMG_20190608_160307.jpg
That's what it looks like finished out.
I disassembled it and sanded it to 60 grit (don't want a slippery platform).
I cut about 1/2" off the depth to remove some cracks and crappy wood on the edges.
Then used a 1/4" roundover bit to roundover all the edges.
Reassembled with a little dab of epoxy in each screw hole to help hold it all together.
Then about 10 coats of pure tung oil.
I prefer oil finishes as they will never flake or peel off. It's important to use a "Pure" oil and not a danish oil or "tung oil" you buy at lowes. They have resins and hardeners in them to make them more suitable for a furniture finish and can flake and crack.
I'll have to reapply the oil every season, or a few times per season but it's a 5 minute job, i'll just do it while cleaning the boat after use.Attached FilesLast edited by SONIC; 06-15-2019, 12:41 PM.
I picked up the first piece of upholstery today to check the placement on the EVA Foam flooring design.
Quite happy with it!
