Headed for a long weekend boat trip to DeGray Lake Arkansas tomorrow so I changed the oil last night. I had the boat hooked up to a fake a lake to run the boat and heat the oil up. Water was coming out the exhaust and all was good. I did rev the boat for about 10 secs to 2500rpm all was good. I was also trying to diagnose and test the spark plugs so I ran it a couple more times at idle the last time I started water would not come out the exhaust. The engine got to temp and we shut it off and I changed the oil.
WELL I put it in the lake today to check oil level and make sure all was good and NOPE water is pouring out of the impeller housing. I'm on my way to pickup a new impeller and housing (luckily Palmer Power in Houston had it in inventory and was willing to stay late till I get there).
My question is did reving the engine to 2500rpm cause this on the fake a lake? or did I have the water pressure on the hose turned up to high? Or am I real unlucky/ lucky depending on how you look at it that it is just a old housing and cracked right now from age?
Could something else have caused this like a blockage? I should know more in a hour when I pull the housing off? Anything to look for. Any way to check for other problems that could have caused this?
Thanks it always seems these things happen hlbefore big trips
