The taps system in my 2006 24ve won't work. I can hear the motor kick on when I press the switch but the plate will not move. It is stuck on 7 and every now and then it will start to slowly go up almost to 6 but then will drop back to 7. I removed the cover to the taps motor and the fill cap and there is a watery fluid inside. Not sure if it is supposed to be like that or not. Any info would be great
Taps system
