Originally posted by dj2
View Post
Question on range of a 2008 22ve with MP340hp
Originally posted by Eighty516 View PostDoes everyone pretty much agree that the taps at 0-1 is the most efficient cruising setting assuming lake conditions are good?I don't want to go to work, take me wake surfing instead!
In the end it's an energy balance equation. The speed of the boat is one output. The size of the wake is the other. If you are putting out a larger wake, more energy is being used to create it vs going forward. In all OB and I/O boats it's as slow of a speed you can go and still stay on plane. I'm still not convinced which is better on an IB with the prop angled down. It's likely the slowest you can go and still be on plane, but these boats don't have a "hump" to climb to get on plane, so maybe less wetted surface wins.
To be safe use about 7 gallons per hour and run around 2800 rpm. the consumption of fuel will depend on wind direction and its velocity, water condition, amount of people on board, number of coolers etc etc. Wake board boats are generally not designed for efficiency. My old 1985 21ft Sea Ray was about 5.5 gallons per hour at 2900rpm and about 29 mph with a 350 CI carburated engine (5.7l) and 17 pitch prop.
