Everyone has their own opinions, but I think one of the main problems is programming. Not just Tige but see it on some of out skiers boats.
My beef with Tige programming- Full retraction at below surf speeds and re-deployemnt upon surf speed. Introduces so much more room for error as the Lenco doesn't have any kind of potentiometer and movement is based solely on times pulses. Those pulses at 14.2v are going to equate to more movement that 13.6v or even battery SOC if not running (surf demo mode on trailer/lift). Also personally don't see the benefit in having an actuator cycle that many times. Why not deploy it and leave it down. I have run many skiers choice boats that do exactly that and I notice no handling problems with turnarounds to pick up riders and then coming out of the hole with rider in tow with plate deployed constantly. Believe constant cycling isn't giving the same exact wave every time. Put tab down and leave it down.
My beef with skiers, because everyone has stinky poops-
Their programmed retraction time isn't long enough when switching from surf left to surf right which results in tabs hanging down below the hull and adding hook so if you surf regular, switch to goofy, and then back to regular port side tab will be hanging down and push into wave causing mush. That's just what I'm observing. The only answer so far is to kill master switch and reboot as computer runs a retraction to start at 0 as has previously been discussed.
As IDboating state they are all running "dumb" Lencos so to me the answers seem to be programming via Murphy. A lot of these tech changes in the last two years on both brands have been great and really we are all the best R&D you can ask for. Just hope they can listen and come up with some solutions.
