We took on some water the other weekend from the fill plug coming off a fat sac. Noticed it when the belts started squealing, freaked me out but we got it all pumped out and everything seems fine. Today I fired it up on the hose to check for leaky hoses and put it in gear and the prop shaft started howling real bad. Is there a bearing for the shaft that may have gone bad or any way to grease it?
Howling prop shaft
Is there a bearing for the shaft that may have gone badMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
