I have been considering upgrading my prop as of late. I have no real issues with my current prop, but I have heard an upgrade can really wake an older boat like mine up. The boat is a 1999 21v Riders Edition; 1:1 Velvet Drive transmission with the 1:1 black Walter V-drive. Currently I have what I believe is the stock prop on it, which is an OJ 13x13 4-blade. I currently surf only, and run around 900lbs port side, 700lbs starboard, and 300lbs up front + suck gate with one or two other people in the boat. We run right around 10.8-11 MPH which equates to roughly 2900 RPM. Top speed does not matter to me at all as I rarely go above 25 MPH.
I called ACME the other day who recommended going with the 1231 13x11 3 blade as their first choice, or the 911 13x10.5 as their second. I guess my main question is, would this upgrade be worth the money? Currently the boat does well on fuel, only running at 2900 RPM surfing. Will changing the prop affect anything surf related, such as RPM, or strain on the engine? With a little over 700 hours on the '99 I don't want to push the thing too hard
Any thoughts/advice/comments would be appreciated - thanks!
