Hi, recently purchased 03 22V, when I returned home from our first day out in it I noticed a lot of water in the bow storage area under the seating, in the other boats I have had this would drain in to the bilge area, is this normal on the 22V ?
22V water in bow
Check this thread out: http://www.tigeowners.com/forum/show...=&threadid=497
It first appears to be an old thread but there are some recent posts.
water in bow
I also have an 03 22v. I was having problems with water in the bow, but never took water over the bow. After some looking around, I found that the sealant around my bow hook was bad. Right where you connect it to the trailer. I unbolted it, got some 3m marine sealant rated for below the water line, squirted it through the holes, and put it back together. My bow has been dry ever since
Have someone hose down your bow lights while you check for water inside!Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
