Once you know ratio Josh, we can see where the tradeoff is. If its a 1.7 My guess is you will end up being around the 15.5 x 13 or 15.5 x 14. That should bring you down roughly 250-300 rpm plus from where you are now if you are running a 15 x 12 with a gain in bottom end bite and a little gain in top end as well. The bigger diameter is key if that ratio is around 1.7 you should be able to push into the 16s without issue..... the question mark like ive said is ration and clearance.
Why Did Indmar Reinvent The Wheel?
The prop on there now is a 2315. The trans tag has two ratios on it: 1.46 and 1.51. Not sure which it is but they aren't much different. The trans model number is ZF45IV. I have 7/8" clearance to the hull and 1 5/8" to the prop guard. Nettles is expecting to get at least one prop ha I from me soon. I can swap out to a 15.5 if you guys think that's the answer. The guy at acme was having a hard time explaining the difference between a larger prop with more pitch vs a smaller one with less pitch. Seems to me they cancle each other out.
I would be very happy if it was just a prop swap. I have to admit I'm doubting.
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Am I the only one that thinks that 5350 pounds ballast with a heavy rear bias may simply be too much for this engine /tranny combo? Without a 2:1 ratio and a 17 inch prop, I think you may be fighting a losing battle.
I love hearing the gear heads talk, and admire your drive to get the max from the boat.Be excellent to one another.
Originally posted by talltigeguy View PostI love hearing the gear heads talk, and admire your drive to get the max from the boat.
So why are you running a less aggressive prop 2315 vs 2419?
If you only have 7/8 then we could push maybe to a 15.5 and try it. Take it run it for 10 and see if we have any prop burn...
I still think a prop can fix all of your issues.Germaine Marine
As usual, late to the chatter. Been super stimulating so far. I'm curious what aftermarket cam swap you are looking at it. Also there is a bunch of Raptor talk flying around. I don't follow MB that closely, but I know for many years they had a bunch of 343, 409, and ZR6 PCMs crammed in them. Sounds like you have and Indmar pre Raptor, assuming M60...just haven't had the chance to see this configuration and was curious if it was just a few years in between.
Did MB also option out the 5.7 in this same weird crossover. Or am I just missing the boat completely??Last edited by freeheel4life; 07-07-2017, 08:08 AM.
Originally posted by UNSTUCK View PostThe prop on there now is a 2315. The trans tag has two ratios on it: 1.46 and 1.51. Not sure which it is but they aren't much different. The trans model number is ZF45IV. I have 7/8" clearance to the hull and 1 5/8" to the prop guard. Nettles is expecting to get at least one prop ha I from me soon. I can swap out to a 15.5 if you guys think that's the answer. The guy at acme was having a hard time explaining the difference between a larger prop with more pitch vs a smaller one with less pitch. Seems to me they cancle each other out.
The hull/trailer are going to physically determine the max diameter we can go. However, the engine will also. We can only drive so much wheel. This is where the newer v-drive ratios are coming into play on these boats driving the 15+ inch wheels. We are able to spin the large props through gear reduction without robbing horse power to do it.
The engine is also going to limit the drop in pitch. At some point, the RPMs are too high and we are out of a usable power curve of the engine.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I don't need to echo what Mike said...
Unless your motor is hurt I can't see why it's having so much trouble. The 400 raptor with the 2419 and 1.5-1 is an absolute monster at elevation with 4500 lbs of weight. You are another grand, and that may be a big problem especially if that motor power wise is inferior.
Go up to a 15.5 x 13 or 15.5 x 14 and let's see what happens.Germaine Marine
Go to 15.5 and take the riskLast edited by Germaine Marine; 07-07-2017, 03:30 PM.Germaine Marine
Originally posted by talltigeguy View PostAm I the only one that thinks that 5350 pounds ballast with a heavy rear bias may simply be too much for this engine /tranny combo? Without a 2:1 ratio and a 17 inch prop, I think you may be fighting a losing battle.
In other words, given the rise of the 2:1 ratios and 575 motors with the 11-12K pound boat crowd, your situation is known and has been re-engineered for. I would never mess with a recreational towboat engine like you are talking about. These boats are meant to be run...not tinkered on or hot rodded to the point it will leave you and your family stranded out on some lake at dusk with a storm a brewin.
I still maintain that the search for the perfect surf wave can cause waaaay too much stress and lack of satisfaction than it's worth sometimes. I think you should go back to your original maiden voyage where you had a "surfable" wave and just enjoy it. Sounds like you can get where you need to with an 11 pitch prop and 4K RPM. That said....you are putting significant stresses on your 1 1/8 shaft going 11-12K pounds.
Anyways, just my opinions. I think you should just spend the money on a hydrofoil and you will be waay ahead in terms of fun.Last edited by Bakes5; 07-07-2017, 03:54 PM.
Tigé Expert
- Oct 2014
- 1252
- Great Faces, Great Places--South Dakota!
- Used to have gangsta lean 24Ve; then GSA F24 Tomcat, now a 2016 Supra SE450. Onward we roll!
Unstuck:
I run a 2937 at 1000' and full ballast with small crew and rpm is 4000. Running 13 people mostly adults would never happen. I would have to sacrifice ballast.
I would personally run 800# in rear lockers with 500 in bow and slappers and enjoy the ride. That should and would be a killer wave.
Or go spend 140k on a huge supercharged boat.
Sent from my iPhone using TapatalkTime flies like an arrow; fruit flies like bananas!
Tigé Expert
- Oct 2014
- 1252
I have also run a .150 cupped 15x11 and that drops rpm to 3700 or so, but when it's super hot outside, it isn't happening.
Slap that boat, run a little less weight and you should have a great combo of big boat, good wave.
The 2-1 is going to eliminate the need for big HP very very soon... few more tweaks from the big makers regarding strut and shaft angle and a 400HP/430 Tq small block mated to the 2-1 will be able to push 12k ish without problem.... That 2-1 has made me a believer.Germaine Marine
Sent from my iPhone using TapatalkGermaine Marine
