Props for 2017 Z3
    Props for 2017 Z3
    Acme 1235 or 2247 ? Will run full stock ballast , 250 lead in each rear and bow , so 750 in lead
    If you wanna know what I did , come with me next time...
    acme 2315 or acme 2419
    Germaine Marine
      you wont need 250 in lead in the bow PS. You will need that 250 split over the rear though
      Germaine Marine
        I see they are both 15 × 12 pitch , what is the difference in the 2? would i be loosing that much pull if i went with a 14 pitch? Split lead ? You mean none in bow and 375 in each rear locker?
          Wakemakers website is saying acme 2079
            Dont listen to wakemakers.....
            the 2315 is less aggressive and will have more on top then the 2419. The 19 is a stump puller for big big weight. It was fantastic on my 16z3 with around 4500 lbs of ballast, 12 full size adults surfing. No issues no cav.
            Germaine Marine
              Yes, 375+ in each rear locker..
              Germaine Marine
                I'm running the 2315 with 500 lbs of lead under the rear sacks @ 2300 feet and doing well. Most surfing is done at about 3000 rpm so we're going pretty easy on the gas too.
                Boat is a 2016 z3 with taps 3.
                  I'm running the 2419, full ballast with 250 in each rear corner at 5000', it pulls pretty easily. Top end is somewhere just over 30, getting just a little cavitation pulling people up in rough water
                    WOT with a 15" x 14 is 37mph
                      I have a 2419 prop (Thanks Bakes5!) on a 2016 Z3, Taps 3, 800lb lead (400 in each rear corner) rear ballast at 100% front at 60%. Adjust Taps3 to your preference and enjoy!
                      The 2419 has been great !!
